Meet me in London not playing
Posted by: MacFever on 06 May 2012
Just downloaded the 24/192 edition and my Superunity hangs :
"connecting please wait"
While in itunes on my Mac it plays fine ...
Anyone has a solution ?
Posted on: 06 May 2012 by Goon525
Are you using wifi? You may not have sufficient bandwidth at 192. I had this problem,and switched it to a USB stick, which works fine (as wifi does up to 96 for me).
Posted on: 06 May 2012 by MacFever
No, I use it on a megabit ethernet network
I have put it on an usb drive and again no go :
The songs are there but after a short "loading" nothing happens
Any ideas ?
If I put the original flac file on the usb stick it works !
Once converted to Apple Lossless it wont play ...
Funny thing is that with other flac files (not from the Meet me in London) everything works : flac to m4a and playback with itunes !
Posted on: 06 May 2012 by james n
What are you using to convert from flac to Alac ?
Posted on: 06 May 2012 by voxpop
I had the same problem with 24/192 files that would not play thru my network. It was the home plugs that I used to transmit from the NAS up stairs and the NDX in the living room. I moved the NAS next to the NDX and all files play fine.
Are you using home plugs or connecting fully wired ?
Everything on wired cat 6 cables through the router
Network is not the problem because usb is not playing either
When converting the alac file back to flac it works !
I use the same program to convert 16/44,1 flac to alac and it also works !
Posted on: 07 May 2012 by james n
What is the program ? I had trouble with hi-res Linn and Naim files converted using MAX. They would play on my Linn DS but not on my NDX. Converting the same files using XLD they worked fine.  Try converting to AIFF instead of ALAC if you haven't done so already.
James
Posted on: 07 May 2012 by MacFever
In fact I used both Max and Xld and had the same result
Will try Aiff this evening
Aiff is working, no problems
Anyone knows why alac is not playing ?
Posted on: 07 May 2012 by Joppe
From specs.:
WAV and AIFF (up to 32bit/192kHz) FLAC (up to 24bit/192kHz) ALAC (up to 24bit/96kHz) WMA (up to 16bit/48kHz) must be WMA 9.2 Ogg Vorbis (up to 16bit/48kHz) MP3 and M4a (up to 320kbit/s)
Thanks Joppe, I should have read the user manual for once ...
