I have recently bought a UnitiServe which will connect to my SuperNail, I would really appreciate some advise about setting up this system.
I have an iMac with a Time Capsule wireless network, although the UnitiServe does not have a wireless connection I believe this can be achieved by using Airport Express, which I have.
What cable do I need to connect the US to the SN?
What cable do I need to connect the Airport Express to the SuperNait (iTunes)
How can I get Internet radio or Spotify?
I need an idiots guide to settimg up this lot!
As you can see I'm lost, thank god I kept my vinyl.
Any help much appreciated
RB
Posted on: 06 May 2012 by The Meerkat
Hi there
You more or less have the same set up as me. I have an iMac, Unitiserve (SSD version) and the fantastic Supernait! The best way to connect the Serve to the Nait is by a digital Coaxial cable. That is what I use, and am at present, saving for a DC1. (No, not the plane!
It is best, and to avoid drop outs, to use an Ethernet cable to connect your Serve to your router. Your dealer should be able to advice you on all aspects of your set up.
Just as a point of interest, have you managed to update your Unitiserve to 1.6c, or did it come preloaded with the new update? If you read my threads on this matter, you'll see that I having a bit of trouble.
Good luck with your new toys!
