Recognising Sound Files
Posted by: Consciousmess on 08 May 2012
Hi all,
As some of you may be aware, there are apps which listen to music and identify what the song is (e.g. soundhound), so I here is the predicament. Of files on my harddrive, many have come up as "unknown" and so if I wanted to, I could use my iPad and identify all the tracks one-by-one............ But that would take ages as I have 100s of files like this....
So is there a feature on ANY of the media players, where I can select the "Unknown" files as a whole and leave the computer to it - in order to identify what all the files are along with the appropriate album cover??
Surely that is possible if simple apps can identify by listening to them?
Many thanks,
Jon
But this would seem to be what you are after if you use iTunes.
Tune-up on the Mac does that as Winky suggests ... but you need some very obscure recordings if XLD or iTunes could identify the titles ... I've only found about 3 in more than 4000 CDs. I'm sure dBPA would do a similar job on one of those old PCs. [Sorry can't remember if you've upgraded to a Mac yet]
Guido If they can find your tracks ,I'm sure everyone else will be fine. ![]()
No problem BigH, though I'm mainly a mainstream man - for instance XLD searched the freeDB and brought back album art and all the metadata for Sume's rather good Sumut album without a hitch, OK so yes I know Sume are just about everybody's favourite Greenlandic prog-rock group, so I guess that was to be expected, but iTunes had no problem with Dark Side of the Moon (the definitive version) either, which has just been re-released
Which is an excellent record even if not quite as good as the magnificent Heavy On The Drum.
I guess I'm just a middle of the road kind of Guy.
I've not used it so I can't comment definitively. Did it come with a readme.txt or other instructions? Perhaps look for a new drop-down menu in iTunes called Tune-up. That's often how plug-ins make themselves known in the GUI.
The video I posted shows what it does and the web site has further instructions on it.
Hi all,
Well, I think I have found a solution. If I convert all my *.wav files to mp3 I could then use this Tuneup application.
But, all my music files are *.wav so would I lose fidelity if they are converted to mp3?
You see I understand mp3 to be compressed and I don't want that as I have plenty of hard drive space!
Many thanks,
Jon
Jon, in short you need to learn the basics, the reason your music files have no names is because they are wavs or you ripped them with no internet connection.
Seriously the time it will take fannying around trying to fix the situation would be better spent simply re ripping the files..
Don't convert them to MP3. Convert them all to Apple Lossless (ALAC) using whatever you like. Import them into your iTunes Library and use Tuneup to add all the metadata.
But as garyi says, you might be better to just re-rip them into a metadata compatible format (whilst connected to the internet, so your ripping program can find the artwork and data).
