Would like to ask if anyone is currently running NDX/ND5XS with a non-naim amplification?
If yes,stream the n-stream app still display the volume slider button (effectively non functional in this case) under operation?
Posted on: 14 May 2012 by 0rangutan
Buy wouldn't it be better if the NDX/ND5XS did provide (optional) digital volume control?
Streamer straight into power amp (Naim or otherwise) would be a great simple set-up, with full control via N-Stream.
Posted on: 14 May 2012 by PinkHamster
If you were listening at volume levels of 80% and above, that would be the way to go. But bringing the digital volume down to below that level may well have a deteriorating impact on sound quality as the digital signal will not contain the full information any longer.
