Even Naim's own update disc won't update Unitiserve to 1.6c
Posted by: The Meerkat on 12 May 2012
After exhausting all attempt to update my Unitiserve SSD to 1.6c, using my own iso burnt image disc, I contacted Naim. They sent me out their very own update disc. I inserted the disc into the Unitiserve and after about 12-15 seconds it ejected it. After after approximately 20 minutes I switched the unit to shutdown, then to off. Switched it back on. The interface on the browser still shows 1.6b, as does n-serve. (I don't have DTC, as I am a Mac user)
On checking the contents of Naim's own update disc, it shows exactly the same folders and zip folders that I had on my own disc, which means that I was burning the disc correctly in the first place.
If Naim's very own update disc won't work, then I may have to assume the Unitiserve is faulty. Unless of course, anyone has any other suggestions? Phil, if you're looking in, can you help?
Thank you
