Vortexbox on Mac as rip/streamer?
Posted by: T38.45 on 20 May 2012
Just upgraded my old Macmini w/ 1tb, does one know if it's possible to run Vortexbox on it?
Ralf
it sure is. Tog?
Tog, thank you!
I want an easy solution without command-lines and terminal,,,,seems Vortexbox on mac is not that easy,,,,
Unless VB installs differently on a Mac than PC, it will completely erase the OSX and you'll end up with a Mac Mini casing running VB. Is that what you had in mind?
no OSX would be ok, I'll use it only for that purpose
I've not tried running VB on my Mac - I'm not sure if it would run under Parallels (never tried it), but VB likes its own machine - it is essentially a music NAS and it seems a little strange to run a NAS in an OS X window.
Tog has already pointed out some issues ... Mac's are designed to work with their own OS and when so used they just work. I have run Amiga OS on a Mac in a Virtual PC window, but it was rather pointless and was just something I did for no sane reason - didn't work very well so I deleted it.
Why did you want to convert your Mac Mini (great little machine) into a VB?
Hi Guido,
I like to have some Unitiserve or VB approach- put a CD in, ripped, tagged, streamed- done:-)
my Macmini is very old, so I thought to tweak it a bit...
Hello Ralf
XLD can rip all your CDs and will tell you how well it has managed to do it. You won't find a ripper that is more accurate - it uses the same tech as the VB or its own engine. It is all menu driven.
Unfortunately, there is no streamer (UPnP) built in to OS X, but you can connect through a hiFace or Halide Bridge to S/PDIF or you can install Playback to stream (I do not use this regularly, but when I tried it it worked very well) - james uses it and likes it.
XLD is free and Playback is a try before you buy - so you could see if this does the trick.
All the best, Guy
PS - Ignore the XLD site as this makes it look like lots of commands, the app is very friendly and has easy to use menus.
Thank you again Guido!
Ralf
If you have a old windoz computer just clean it out and turn it into a Vortex box.
You wont be able to use it for anything else.
You can buy a new 1TB vortex box for a few hundred squid
Dont mess with your Mac its to good.
Stu.
