Good, reliable server for UPnP and family photos, vids etc
Posted by: CraigB on 27 May 2012
This great weekend of weather is coming to a close and after taking a bunch more photos of the kids, it's got me thinking that I really ought to sort out a good server, rather than relying on my netbook.
I've lost my ripped music collection several times over the last 5 years, but hey it's only music and i simply go into the garage and get out the CDs for another ripping session. But the thought of losing all the family pictures terrifies me. Although I back up onto external hard disc often, it's not ideal and I'd like a better, more reliable option.
I'd be interested to hear what you use for your all your music files and digital media, and what your opinions are of its safety (against total loss) and reliability.
Thanks & regards,
Craig.
Hi Craig
I am in a similar position to you re not wishing to lose photos, all those ripped CDs etc.
I have 2 separate Synology NAS drives, located in different parts of the house but connected via CAT6 cable to a common gigabit switch. The back up routine runs twice a week to copy data from one to the other.
I am sure that you could do the same with QNAP or Readynas Duo drives.
Best regards
FT
Some specific questions:
Tog - Does the Vortexbox have a built in upnp server? I also have a SB3 which forms the heart of my kitchen system so the server should have LMS as well. My NDX doesn't play files from LMS - something about incompatible file type but they are just FLAC in the end. Any ideas?
FT - sounds like a robust simple backup system you've got there. Stellar music system by the way, based on your profile.
Engjoo - the raid 1 means just one disc in your server, which you then duplicate to your desktop hard disc?
Ian - cheers for that, sounds like a very cost effective system. I have a lot of photos on PS3 disc. Do you think the Windows Server could also back these up?
Thanks again all and apologies for any dumb questions. It sounds like a combination of suitable hardware but also common sense regarding back up regimes is the best approach as you all have implemented.
Craig.
Craig
I know nothing about photographs, but the Vortexbox has a superb UPnP server that works faultlessly with Naim kit (well certainly with my UnitiQute), it also supports Logitech SB/SBT, Sonos and Apple devices. If you have an old PC that you don't mind sacrificing you can turn it in to a Vortexbox for free and give it a go. You can download the software, which is absolutely free, from the Vortexbox.org site - the Vortexbox is optimised for FLAC and it will NOT transcode on the fly (I haven't found any need to do this, but some folk like to do it).
If you are considering a VB then I'd try it first - I did and am now not considering an alternative because in Apple-like style it just works. The VB runs Linux, which means it has excellent operating system at its foundation; I'm allergic to Windows.
Back up is really simple with VB, as are most things - nothing fancy just does the essentials very well.
I built my VB myself (it was easy it was cheap go and do it - Desperate Bicycles), but you can buy pre-built ones to almost any specification.
Hope that helps, Guy
Me too
Hi Craig
I think that the point with photos would be to store these (and other media/data files) on the server rather than the PS3 and use the server as a NAS (and make sure you back it up!) I keep everything on the server, sync it automatically with my PC (using Live Mesh), back it up regularly (WHS2011 does this twice a day automatically), and back it up offsite too (in real time using CrashPlan).
Ian
J River.
