Majestic - Artists wrong sorting
Posted by: chrismuc on 07 June 2012
I am testing Majestic Server Software on my MacMini with a UnitiQute.
Everything works fine except the iTunes Artists list is not sorted alphabetically ... Which makes it quite impossible to use. It seems the artists listing is in alphabetical order of the ALBUM names.
Does anybody have the same problem? And maybe a solution?
Chris
Posted on: 07 June 2012 by james n
Hi Chris - are they following any sort of pattern. I've tried to recreate what you are doing with Majestic but always get the artists labeled in alphabetical order ?
Try Yazsoft Playback. I've just gone back to this after using Majestic for a few months.
James
Posted on: 07 June 2012 by chrismuc
Thanks James,
I do use Playback in the moment and it works fine.
I just liked Majestic giving me artwork in the album view
I think majestic is sorting the artists by album name, which obviously makes it difficult to navigate.
But it's interesting that you don't have that issue. I'll tso around a little and meanwhile stick with playback.
Chris
