JRiver Media Center with JPlay Plugin
Posted by: Hot Rats on 07 June 2012
My streaming system is as follows:
NAC52/Supercap
NAP250
SBLs
Windows 7 (x64) Laptop
JRiver Media Center 17 (Latest Update Installed)
M2Tech Evo/Paul Hynes SR-130 Power Supply
Naim DAC/XPS
I use JRemote app to remote control JRiver Media Center from either iPad or iPhone
I wondered if anyone else was using JRMC and whether they had tried the JPlay plugin:
www.jplay.eu
There are some big claims being made for this software and the improvement that it offers over the standard JRMC package. It's not cheap at £80 though.
Does anyone have experience of using the JPlay plugin with JRMC and if so, are the benefits worth the outlay
Posted on: 07 June 2012 by Aleg
You can download their trial version. It is fully funcitonal but will nag you with a pause in music playback every minute I believe.
But it gives you the opportunity to experience it for yourself.
I love this program, but only use it via the JPlaymini user interface.
JPlayMini and fullscale hibernation is mindblowing.
aleg
