Naim DAC USB connection
Posted by: 56wilson on 08 June 2012
Can you connect your laptop or pc to the Naim DAC through the USB port, or is it only for ipod/memory stick connection?
Posted on: 08 June 2012 by Aleg
No, its only for USB stick.
Aleg
Posted on: 08 June 2012 by Zinger
Wilson, you will need USB-SPDIF converter in between
Posted on: 08 June 2012 by Guido Fawkes
hiFace or Halide Bridge should do the trick - USB in to MacBook and S/PDIF in to Naim DAC - no drivers required: simple.
A general purpose USB port on the Naim DAC would degrade its sound quality with extra noise so is avoided. It is possible to engineer a good USB connection, but this would probably put £1,000 on the price so best to use one of the above.
I don't think the NDS has any USB for music, but there is a mini-USB for something - hopefully upgrades from a Mac or PC
