Asset upnp and your own compilations
Posted by: Dungassin on 14 June 2012
Just come across something that wasn't obvious to me from the Asset help files.
I'm currently transferring some of my favourite LPs to digital format for use with the NDX in my study AV system (alas, there is no way I can fit a turntable in here!). So I've been adding these files to my multimedia directory on the NAS. This means entering all the tags manually (tedious, but that's the way it goes)
I had just been playing them with Twonky while adding more, but earlier today I got round to actually playing some of these added files using Asset. No problem with single artist albums, but I noticed that compliation albums were not displaying correctly when using album as the search field. Every artist on a compilation was coming up as a separate album! In Twonky, the albums appeared correctly.
After a little bit of thought I looked at the tags for the compilation albums, and realised that the COMPILATION tag wasn't there. So ... I added it, set the parameter to 1, and all is now well.
Just thought this info might be useful for any other newbie doing the same thing. ![]()
