DVD Audio rip not as good as CD rip
Posted by: Kage on 20 June 2012
Can someone shed some light on why I am experiencing better sound with a CD rip vs a DVD-A rip?
I've downloaded the DVD-Audio Extrator and set about ripping a copy of The Beatles 'Love' album. The settings within the program were:
DVD source: [/dev/rdisk2] HL-DT-ST-DVDRW GA32N (KC08)
MLP (96kHz 24bit 6ch)
Output format: WAV--PCM Uncompressed Wave
Setting details
Sample rate: Same as input
Channels: Stereo
Bits per sample: 24 bits
In comparison the DVD rip compared to my CD rip loses some details. It sounds smoother and less 'hard' but misses clarity and effects that the CD rip has. Could this be due to the 6ch (5.1) compression down to stereo 2 channel? If so, there isn't a stereo version selectable within the program, but there is on the DVD.
Shall I assume that DVD-A discs are best left to be played by a dedicated DVD player that supports the DVD-A format?
Kage
ND5 XS, NAIT XS, SYNOLOGY DS212J
