AV2 Problem after 3.5 years of operating, since last repair.
Posted by: Kingfish on 10 July 2012
My AV2 did not turn on when I pressed standby on the remote.
When I manually turned the device on, it had lost all of the settings.
I re-entered all the settings and the device seemed to work okay, however while testing, the device would lose any digital signal, after five minutes of use. The digital signal came from two separate devices on two separate inputs.
Does this sound like a previously known problem?
Thanks for any helpful info,
Mike
Posted on: 09 August 2012 by rackkit
Any luck with your AV2 Mike?
Posted on: 09 August 2012 by Kingfish
It went back to Naim. I am still waiting on it to return, Repair cost 875 Euros.
Posted on: 13 August 2012 by rackkit
Ouch! I've seen working models sell for less on the used market.
