DVD 5 - plays no cd's
Posted by: christoph on 20 July 2012
Hi all, my dvd 5 plays no cd's. if you put one in, the display shows "cd", and you can hear it work normally. but there's no sound. dvd works perfectly. i can't understand this. Any advice? thank you.
christoph
Posted on: 21 July 2012 by Mr Underhill
C,
I have had similar issues on my DVD5 twice in the past, on both occasions it had to go back to HQ.
M
Posted on: 22 July 2012 by christoph
M.,
i will do that, thank you for the answer.
christoph
