Internet Radio with Mac
Posted by: dieterj on 21 July 2012
Hello all,
my Problem, i can't connect to Internet Radio with my Userve.
The Userve is wired with cat5 to Time Capsule and my iMac.
Thanks for Help
Posted on: 22 July 2012 by garyi
If yo can see your serve from the network then its likely the serve has the wrong DNS information, did you set the IP of it?
Posted on: 22 July 2012 by dieterj
Hello garyi,
i can see the US over the Internet, but when i look to System Status, i don't have settings for IP, Subnet, DNS.
Is your US secondhand?
It looks to be a simple IP problem.
No, i'm the first Owner. The US worked for long Time with no Problem. I give a fixed IP.
Can i reset the US?
I would start with Changing the serve overto dhcp. Sorry i wouldnt know how.
Has your isp changed dns addresses? I think that will be the simple issue.
Thanks garyi for Tips, first i will ask my ISP.
