Naim and Twonkey
Posted by: Michael Walter on 02 August 2012
Hello
Until now I have used a windows based twonkey media server and as a better choice an Asset (which is the best) media server, mainly to stream music to my Naim ND5XS (Firmware 3.09). To control the server and the Naim, I had Elyric, n-Stream and Plug player as an IPad app in use. But to control all features I like to prefer the Naim App
However, for data safety I thought it would be wise to invest some money into a QNAP TS212 Raid 1 system.
And here starts the problem, using the twonkey as it comes with the QNAP I found out the all album picture are fuzzy and strong pixel as long as I use the maim app, when I switched to the plug player or the elyric it went perfect as before.
I like to get some help how to make the naim app working in combination with the twonkey on my QNAP
Sorry for the bad english
Posted on: 02 August 2012 by Steven Shaw
The solution was discussed in this thread
https://forums.naimaudio.com/di...46#17194513573339346
Hope this helps.
Posted on: 02 August 2012 by Michael Walter
Thank you very much.........................perfect
Posted on: 03 August 2012 by Tog
The return of "wonky Twonky" - best solution - don't use it at all. Tog
