N-Stream naim unitiqute - reverse or forward
Posted by: nocciolo on 08 August 2012
Hi,
i have a question.
n-stream 3.0 for unitiqute and the unitiqute provides the function reverse or forward?
with either the remote or with the application I can not quickly scroll through songs.
tx!
Enrico
Posted on: 09 August 2012 by garyi
Correct.
Posted on: 09 August 2012 by nocciolo
Originally Posted by garyi:
Correct.
Sorry garyi but i do not  understand.
I can not use options reverse or forward. these options are not currently operational and planned?
If so in the future will be placed in your opinion?
Tx a lot!
Enrico
Posted on: 09 August 2012 by Harry
You can't FF or FR a streamer from the handset? I'm grateful for that information because setting up my URC for this was on my To Do list, after I noticed the buttons on the remote. Since the remote probably covers a number of products I assume the feature is redundant for the NDS. I'd certainly not want to fiddle about with it for nothing. Interrupts the listening.
So I'm still don't understand if is possible or not.
I use the iPad as remote controller(http://itunes.apple.com/us/app...eam/id381694252?mt=8) and the naim remote (http://www.naimaudio.com/hifi-products/pdt-type/198).
Both of them are not working, does anybody know why?
Thanks in advance for you support!
Posted on: 10 August 2012 by Harry
On iPad it is not possible.
On remote - try it. My understanding from this thread is that it is not possible.
I'm sure I've read that a future iteration of nStream will incorporate this.
Posted on: 10 August 2012 by nocciolo
ok 1000 tx!
