Latest nStream update
Posted by: Tog on 21 August 2012
New update out - not certain of the differences yet.
Tog
Posted on: 21 August 2012 by Minigill
Playlists !  Yahooo! Just tried.
Alphabet instead of dots down the side.
To me, the text is clearer in the lists.
Not sure about anything else yet !
Posted on: 21 August 2012 by AntonD
Hi Minigill
I take it your streamer updated successfully to 3.16?
Unfortunately mine didn't and has a "fault 36" displayed on the unit.
Anton
Posted on: 21 August 2012 by Peter_RN
Did you follow the advice to update to 3.13 first?
http://www.naimaudio.com/news/...nables-playlists-all
Yep. IT/ software is the industry I work in so know quite a bit about this subject and products/devices. Already spoken with Naim and it appears my fault means a return to the factory.
I was so impressed with my nd5 until 1 hour ago. I'll have to think now if I want it back!
Was really looking forward to a listening session tonight
Anton
Originally Posted by AntonD:
Hi Minigill
Anton
Hi Anton
Yes, updated fine, took a while, but all ok.
Gill
Well done. Enjoy your tunes tonight
Posted on: 21 August 2012 by Alexb
Yesssss, very happy with this update!
The queue is what I wanted. Now I can look for what to play while listening.
Alex
Posted on: 21 August 2012 by Iver van de Zand
update went smoothly. New functionality was worth waiting. The queue is very nice and playlists was in my top-wish-list
unless I am wrong, but does the albumart look better ?
Posted on: 21 August 2012 by RexManning
I don't understand how I can see what firmware version I am on right now. Is it under "Version" (3.9.00) or "Boot version" (1.2.22)? I would think not, but then I can't locate where I could see it. Anyone?
You can see the version from the app either on the ipad or phone under settings.   Naim recommends it should be 3.13 before running the new update.
Or via the handset/Streamer
Tools > Factory Settings > System Status, then scroll down until you reach firmware.
Gill
Posted on: 21 August 2012 by Thorsten_L
Everything went smoothly.
Awesome update, both for ND5XS and n-stream.
Update. Just powered nd5 back up after off for approx 1.5 hrs and guess what?
She works
New n-stream looking good the alphabet to the right and new playlist functionality looks great. Music back on folks!
A happy Anton here
I like it now it goes back to what you were listening to when the app shuts, instead of 'restoring history' everytime when you go back into the app.
Great news then Anton, welcome to the party
Thank you. Will celebrate with a monster listening session and give the new app a good workout. Looking good so far.
Anton
Posted on: 21 August 2012 by ernie
just updated without any problem. However nStream now messes up with album order. I use asset upnp and prefer the album order "album by artist" for alphabetical artist order first and second by album. But nStream ignores that now. I get always the alphabetical album order only - but I don't like that with unsorted artists. I just can switch to artists, but then I can't see all album covers directly.
Does someone knows how to work around? I couldn't find an additional setting in asset controls.
In track navigation still doesn't work or am I wrong?
Gill
Both app and system status don't say: "Firmware version", but unit version (3.09.00). I guess that's it then. Starting the upgrade!
Just checked the phone, it says 'streamer version', so meaning the same thing!
Good luck !
Posted on: 21 August 2012 by Tog
Looks like I need a board update or a new streamer.
Yep - looked at the instructions - nope I don't have and will not give houseroom to a Win PC.....
Yes I do need the new streamer board - do I upgrade my Uniti or trade in? SuperUniti?
Tog
Posted on: 21 August 2012 by Kaver
Touching a song in n-stream it now asks whether to play it or add it to a playlist etc. Is it possible to disable this feature so that it immediately plays the song, so that one doesn't have to touch the screen twice for playing a song?
Tog, fortunately I have windows pc for work otherwise I would be in same predicament here. I think Naim need to sort this in the future.
SU sounds good though
Posted on: 21 August 2012 by Chaton
Nothing for android yet, but I dont care I will keep my squeezebox touch long time and forget about Naim streamers
Posted on: 21 August 2012 by Simon-in-Suffolk
Great upgrade.. Now I can mention the dynamic playlists for the NDX, absolutely superb.. Just make sure your NAS or wherever your files are kept has a static IP address... Nice touch with the vey latest Nstream you can selectively remove unreferencable files from your playlist.
Also the sound has improved even further (kind of more complete and layered), and this includes sending spdif to the ndac.. I quizzed naim about this as i thought i must be going nuts but  they advised me that they have tweaked the DSP controller code.. Perhaps matching it to the same build as the NDS.. Really nice .. Makes be pleased to be a Naim customer.
Simon
Posted on: 21 August 2012 by james n
Damn you Simon. I wasn't going to bother updating but you've piqued my interest. Now to find a Windows PC
Posted on: 21 August 2012 by unclegaz
Hi guys,
I dont have a rs 232 cable. Can I don it any other way?
