Useful NAS setup guide
Posted by: james n on 04 September 2012
Courtesy of Naims FB page
http://www.whathifi.com/blog/o...d-time-again…
Posted on: 27 September 2012 by Stefan Vogt
Hello James,
thanks for this. I have seen another very helpful comment of yours in January 2012 (topic: NAS with UPnP with Superuniti). It sounds as if the openness of a mac mini-based system is hard to beat!
You mentioned that you also rip for iPods: can you remind me if one to rip to hi-res (e.g., AIFF) and lower-res (e.g. AAC) at the same time, please? I have seen 'create AAC version' in iTunes, but this puts the new file into the same folder )-; Rather, I think I have read somewhere (!) that it is possible to set up one iTunes library for all hi-res files, and another iTunes for low-res (AAC)? Was this with XLD, or iTunes...?
I hope you can help,
Best,
Stefan
Posted on: 28 September 2012 by Gavin B
Hi Stefan
Perhaps not a full answer to your question, but...
If you rip to loseless in iTunes, you can choose the resolution of the files you sync to your other i-devices when you do the sync/transfer.  You can choose different resolutions for each device.
My loseless library is way too big for my 64GB iPod Touch so I choose to transfer then at 256k.  It's just for use in the car so the quality is just fine.
Gavin
Posted on: 29 September 2012 by naimUnT
Over at the Harbeth forum, there is also a post which just started for beginner's hoping to get started on building their own NAS SSD.
Posted on: 30 September 2012 by james n
Originally Posted by Gavin B:
Hi Stefan
Gavin
Hi Stefan. I do the same as Gavin for my car iPod - a useful way of loading up the iPod wihout needing to keep another folder of lower res music in my main library. The only thing i dont like is that its limited to 256k.
I usually just have a selection of full fat AIFF for my work IPod.
James
