1 month owner of SuperUniti... Not really happy
Posted by: revmis on 06 September 2012
Hi all,
I have been the owner of SuperUniti for a month now. Just upgraded the firm ware to
SU: 3.16.00 western europe+N-stream 3.1.
Speaker is Proac D18 with Naca5.
Control with Ipad 2+N-stream and Ipeng to compare
My previous system to compare: Nait XS+Proac D1+Squeezebox Touch (SQT)with soundcheck mod)+ Music Fidelity DAC M1+ Ipad 2 running Ipeng
Within the 1st month of ownership, I cannot comment on the sound quality right now as it seems quite good, and I hope it will open up furthermore. But I encounter so many hiccups with my SU, that I would like to share here and hopefully that someone will tell me what I have done wrong, or something is not right with my system. This is a long post and I am not native English speaker so pardon my writings ![]()
1/ From the day 1 until now: I cannot connect to wired. Have tried 3 cables,switch the outlet, SU factory reset,router reset, fix IP address. Cables fine,router fine,because I try all cables with 2 laptops, Ps3, Dune D1 they can connect and surf. My Buffalo wireless N router had been rock solid for 3yrs, no problem whatsoever with all the gadgets I have: 2 laptops, 1 netbook, 2 ipads, 1 blackberry, 1 nook, ps3 . Very strange. I can say SU is picky, and if I have to buy a new wireless router just for the SU ... not really happy. So I give up on the wired, use wireless for now.
2/Firmware update: SU came with 3.13 so I try to update and oh my god this is horrible. After the 1st stage update, at 2nd stage updating the DSP DAC,the laptop could not find SU. I tried switching the cable,check the IP it just could not connect like 5 times. And this is strange: when I got into setting -system status to check IP,I swore to god I saw it said"WIRED" the first and only time ever. Then somehow after changing cables, re-enter IP, turn on and off, it could connect and ran finish the update. Magic!! After update, SU back to wireless, cannot connect to Wired ever since, with either DHCP on or off. What the heck??I consider myself fairly knowledgeable in IT and computer stuff, not completely idiot, so i don't know why![]()
3/ IRadio: I suspect because it is wireless, not wired, then IRadio drops like crazy every 10 seconds, even Radio Paradise 128kb (forget the higher bit rate). What strange is that my SBT(wired)+ DAC M1 run just fine. And if I connect by coaxial from SBT to SU digital 2, then SBT never drops to feed SU Radio, nice and smooth all day long. And in fact that was how I used for SU breakin, together with cycling track from USB stick. My favorite channel: SkyFM, Radio paradise, BBC1 and 3, Linn station, .. not hi-def, only normal bitrate. Internet speed is quite good,as I can reach to 700KB/s or better, so why it drops?
4/ FM Radio: how come it cannot pick up any channel? should I install antenna for it? For comparison, my Pioneer VSX-21TXH and my bed radio clock in the same room with the SU can pick up quite a handful channels?
5/USB stick and USB drive playback: never show any album with art work. I have some albums in wave+cue. On my SBT is fine, but on SU, cannot read?
6/ uPnP: I do not have a NAS at the moment. So I run windows media 12 as streaming server from my laptop. Laptop also run Squeezebox Server to feed SBT.
This time I got error "Server not respond". Fix that by choose compatible uPnP
. but using compatible uPnp disable the play queue I believe, and also disable the squeezebox server (cannot find if in compatible mode)
Then, the inconvenience with play tracks still remains: no album art, cannot select single track from CUE, cannot fast forward or reverse.
I have some album in single WAV file with Cue sheet. On the SBT+Ipeng, I can click on the cue and select single track to play or fast forward/reverse/select mutiple tracks...etc. On SU, show only the single wav file, no way to know which track is playing.
I also have some APE files, which can be read instantly on SBT+Ipeng, but no luck with SU
So right now I stream by windows media server in compatible uPnP mode but open Ipeng to see tracks, album art. Ah "funnily"painful
7/User interface: I dare say N-stream is miles behind SBT+IPeng. Album art+playlist manage better+ shuffle better+radio is better+file compatible is better. Stable and rock solid for 1 year. On my Ipad 2, if I browse the web then come back to N-stream, always annoy to see "connecting" with the clock cycle then about 2 seconds N-stream appears. IPeng never does this. Anyone has been using IPeng with SBT, can you agree with me on this 7?
8/Remote: not backlit. While the remote is nice and sturdy, how come a "near-6K-USD-purchase" come with this?my cheaper Pioneer at least has backlit on the volume key. It is not big deal 'cause after a while i can remember where to click, but inconvenient nevertheless
I am an easy guy but after spending much on a set like this , I must say I am not totally happy. Should I return and change to another one?Local dealer is not very helpful as I can sense they know nothing better than me about the SU. In fact when I ask if they have SU in stock,their only answer is Supernait
. I read the this Naim forum frequently and I can say that I know about the Naim system better than them, thanks to a very helpful Naim forum
Am I assuming correctly that a NAS or dedicated Vortexbox can solve the problem 5-6-7, and switching to another gigabit router can fix problem 1 and 3? I can live with a few hiccups here as soon as the sound is excellent and I think it will be, but of course not happy
Sorry for a very long post and thank you for everybody to read this
