how to incorporate subwoofer in cd system
Posted by: tom2 on 10 September 2012
have an old cds+nac52+2xnap250 and active sbls
system now pretty old but still sounds good
have connected tv to aux input in pre amp to give films a decent sound
would like to connect sub woofer to systems for dvds on tv but do not want to loose cd playback sound quality
any comments on suitable subwoofer and how best to connect to give films more ooomph without destroying sound on cd playback gratefully accepted
(ps dont want to buy separate home cinema kit with millions of speakers etc)
Posted on: 11 September 2012 by Massimo Bertola
Hi,
I have owned a Naim N-Sub for some time, and used it both for cinema and for music in a stereo system (CDX2, Supernait, N-Sats). Since I assume you have at least one PSU in your system, all I can say is that the N-Sub is an excellent sub, never invasive and rather discrete instead, great for cinema and extremely clever as to settings and versatility; and it can be fed from the output of a preamp or a PSU, like one would do with a power amp, with a 4-pin DIN to 2 x RCA cord.
In case you should decide for a 3rd party subwoofer, I think that the same connection can be used for any other unit.
The special cable needed can be had from Naim or from 3rd party makers; you can get excellent advice from Naim, as I had.
With the N-sub, which is remote controlled in all of its functions, it was very easy for me to start at zero level and slowly increase the sub's loudness until I started hearing the lowest frequencies at a minimum intensity while the Sats retained their voice, with no boom added; and this was the setting for me.
But you can decide for two separate settings for cinema and music, and preset each.
I hope this helps,
Max
