My Plan on Mac Mini as Music Server - opinions please
Posted by: mikapoh on 13 September 2012
Hi Guys,
This is the first time I take the courage to venture into audio streaming world since Naim DAC has joined the family couple of months back. The objective is to play Hi Res files while retaining CD5XS for CD playback. My intention is to get both players feed into nDAC for processing. After some thoughts and readings, I have decided to opt for latest Mac Mini as the digital transport/music server. The rest of the audio chain consists of nDAC wired to Nait XS/FC XS using Hi-Line and finally NACA5 to a pair of Harbeth C7ES3.
I have gathered some info on how to optimize the Mac Mini and plan to build based on the following system. A latest Snow Leopard OS Mac Mini with 8Gb RAM, installed with internal drive of 500Gb (no SSD). Running iTune/Bit Perfect together and store my music library in external self powered USB 2.0 1TB HDD (WD MyBook). The Mac Mini will feed into nDAC using optical cable such as WireWorld Supernova 6 and hence, favour USB HDD over Firewire type for cheaper option. I will use my PC in another room to source/download music online and convert them into AIFF format. Subsequently back-up will be done in the PC hard drives, and then stream wireless the AIFF files directly to the external HDD attached to Mac Mini (by sharing out the HDD via homegroup). I know when transferring files through wireless home network into Mac Mini ext HDD will put it under stress (not good for audio), I can always do it outside my listening session. When I sit down and listen to music, the Mac Mini will solely play iTunes and no other task.
Would you think this configuration is desirable? or have I planned wrongly which is detrimental as far as SQ is concerned? I would like to avoid NAS at the moment since my music files are not large to warrant such investment.
Do you think the Mac Mini combination playing Hi Res music can match the SQ of CD5XS, both feed into nDAC?
I do not wish to spend a fortune just to better it (CD5XS). I agreed with Guido what comes after nDAC analogue section is far more critical than the digital transport.
Any thoughts are welcome.
mikapoh.
