Downloading "Hi Def" Music
Posted by: Russ on 18 September 2012
I am now attempting to educate myself on the basics--(the how-to)-- of downloading what I will call "Hi Def" music (by which I mean CD quality on up). But first a question about ripping CD s:
I know that when I rip a CD onto a computer file, using a PC, I need to do so with adequate software--such as dbpoweramp. Q: Am I correct that Windows Media Player is not adequate to rip CD s into CD quality or higher? I realize that if I use either a VTB Appliance or a Unitiserve, I don't need to worry about this and the rip is relatively seamless.
Now to downloads. I have done my research so far only on the Naimlabel website under FAQ. "How do I download files?" The explanation is straightforward and almost clear to me--but my confidence level in my understanding is not high.
First, I understand from this web page that I do not need a "Download Manager" such as Orbit Downloader, but that if I am going to download multiple files or an entire album, this would be very helpful. So what I THINK I am hearing is that I could select a Naim label album, select a track from that, and download it straight to my PC and pop it into a file, say on a USB stick, then schlepp it over to my Superuniti and play it from the USB port--and I will automatically get the highest bit rate, sampling speed, etc. that I paid for. Am I missing anything?
Again, it is my understanding that a download manager would help me downloading tracks, albums, and artwork together. I think I've got that.
I assume if I tried to play these files using either ITunes or Windows Media Player, I would not get the full SQ I paid for. Am I right so far?
Next the website tells me:
"You can often use other networked media players to connect to this music library and playback the files though your hi-fi system thus exploiting the full audio resolution of the files you have purchased from the Naim Hi Definition Download Store."
I THINK this is telling me that once I have the music downloaded to a file that is seen by something like either the US or the VTB Appliance via UPnP, then that device can serve it to the Superuniti in high def format. True?
I hold in my hand the last question: Assuming a Unitiserve or a Vortexbox Appliance has files of different codcs loaded all over it (I realize the US has different areas for rips vs downloads), when it serves them to the streamer section of the Superuniti or any other streamer, does the equipment recognize the file type and codec automatically? I.e., is that transparent to the listener?
Thanks, as always for the lesson I am about to receive
Russ
