Desktop Client for HDX user interface problem
Posted by: Eugene on 30 September 2012
Very often DTC (ver. 2.0.11.1165) starts not showing the right pannel and the scroll bar. Usually DTC works fine for 2-3 days after installation and then these elements disappear. If they have disappeared nothing can bring them back again. Every time I should reinstall the application using "repair" option from the original CD. Is there any way to solve this issue without reinstall?
