Transfer n-Stream Playlists from one device to another
Posted by: What's My Name on 02 October 2012
I recall seeing somewhere you can transfer playlists created on n-Stream from one i device to another. Just got a new one so want to transfer my playlists to my new device. I believe its done using iTunes but I can't see how.
Any advice or instructions ?
Posted on: 03 October 2012 by TJ
- Connect your i device to your computer
- Open itunes
- Select your device under "DEVICES" on the left panel
- Select "Apps" from the options on the main window
- Under "File sharing" you should see n-Stream
- Select n-Stream and in the "n-Stream Documents" window you will see all of your playlists
- Select the playlists you want to transfer and drag them all to a temporary location (e.g. your desktop)
- Then connect the new i device and select DEVICES > Apps again
- Then drag the playlist files from your desktop into the n-Stream Documents file sharing area
Posted on: 03 October 2012 by What's My Name
Thank TJ, will give it a try. Is there somewhere that we could post these type of instructions for n-stream ? I looked on knowledge base and nothing. Maybe a user manual somewhere ?
