anyone encounter wit ndx before?
Posted by: Joviphang on 14 October 2012
every songs alwalys cut to the next song while leaving 5s more to finish. Anyone encounter this before? Test it on another streamer it was ok.
Posted on: 15 October 2012 by Peter_RN
HI,
Could do with more info on what you are using and how you are server to the streamer.
Are you using Foobar?
Peter
Posted on: 15 October 2012 by Joviphang
Thanks for reply. I using synology>cat 5e>ndx-hicap dr-200&202. Play Flac n wav files. Tried on ds audio & n-stream fro 24-96 to 24-192 all hav same issue. leaving last 5 secs of song n jus skip to the next track when playing. some jus sounded jus cut off to the next track. really weird. tried restart the boxes n reboot my synology. still the same Try playing all the same files again on my room marantz streamer with the same synology>cat 5e>streamer. it was ok, don hav any of this issue. any idea why ndx skip my music 5s before it finished?
Posted on: 16 October 2012 by Peter_RN
I did have a similar issues some time back but from memory I think it was with ALL files not just Hi-Def. My problem was caused by me not using the Qute & NDX as was intended, I was asking the program to send the tracks to the units instead of selecting the music from the units. Changing the way I selected music solved all our issues. We do not use any apps – n-stream etc – so can’t offer advice with that.
The current firmware is 3.16 information on which can be found at:
http://www.naimaudio.com/news/...nables-playlists-all
If you need to update please be sure to read the instruction that you should be running 3.13 before applying the 3.16 Firmware.
It might be worth checking the Naim Knowledge Base to see if your issue has be addressed there.
http://netserverapps.com/naimaudio/users/main.php
Peter
Posted on: 16 October 2012 by Joviphang
Thanks Man! will do that.
Posted on: 21 October 2012 by Ade
I've had this problem using plug player - cutting out 5s before end of track. Never had the problem with nstream, but never did figure out why pp did it - be interested to hear anyone else's thoughts on this too...
