Naim Uniti 2 USB / iPod connection
Posted by: Bluetoo on 18 October 2012
Hi
I'm new to all this so forgive me if I appear inexperienced!
My Uniti 2 is a couple of weeks old and all inputs (analogue/digital/ phono stage/ UPnP streaming etc) are all working fine. When I plug my iPhone 4 or a USB stick in (I have tried different iPod/USBs leads and drives) - none are recognised.
This is the first time I have tried using this input and all the devices work in other machines. No error message - just a display saying No Device - connect USB / iPod.
There appears to be no power coming from the socket as the iPhone does not charge and the light on the USB does not come on - I have checked settings mens to no avail.
I tried turning the Uniti off overnight and then reconnecting it and both the iPhone and the memory stick were recognised and I could play from both, but after switching inputs and then back again - same problem - no device recognised and no power going to either USB or iPhone.
Should I return the unit to my Naim dealer or is there a solution that any of you know of?
Many thanks
Mike
