NAS Factory Reset
Posted by: Gavin B on 26 October 2012
I've been playing with putting files on a Netgear ReadyNAS Duo v1 for a while now.
In trying to change a setting I realised I couldn't log on as the administrator. I decided my only option was to do a factory reset which would lose all my data. This wasn't a problem since it was all on my PC anyway. My first attempt failed - I don't think I held the reset button in long enough.
My second attempt looked like it worked - the LEDs flashed twice at the appropriate intervals and off it whirred. The manual suggested the process would take 30 minutes, but almost 24 hours later it looks like it's still going. It's still whirring away (at least what I assume is the fan) and the Power button is still flashing.
I'm assuming that something's gone wrong, but what should I do? Just turn it off and try again?
I've left a message on the ReadyNAS forum, but no replies yet.
Gavin
