iPad error with HDX
Posted by: ray sheldon on 26 October 2012
Anyone.....
the option to change album cover has stopped working on the iPad. I've:
1. Deleted the nserve app and reinstalled it.
2. Rebooted iPad.
3. Factory reset iPad
4. Rebooted router
5. Rebooted HDX
Same fault, click on an album, select edit, select change cover, select web search, nothing happens, select web search again, app exits and goes to main iPad screen.
I've got web search as google, does it with all web search options under settings on iPad nserve settings.
anyone had same experience?
any suggested solutions?
Thanks,
Posted on: 26 October 2012 by Bart
Ray check out this thread; it's a little lower down on the page:
https://forums.naimaudio.com/di...nt/19447375213592585
Is that your issue?
Bart
Posted on: 26 October 2012 by ray sheldon
Bart, yes, more or less the same issues, thanks.
i dont I understand why the problem would just start though, it's been ok for months and I haven't changed or run any software upgrades etc?
