HDX fails to backup
Posted by: ray sheldon on 01 November 2012
Spent an hour on the phone to Naim and even they couldn't help.
I have the 1tb and have bought a western digital 1tb NAS for backup.
HDX can see mybooklive under network shares, it is also enabled....green dot.
When you select add new music store, it lists everything found under music shares.
When you highlight mybooklive(still green dot), click next, enter password, you get a message saying : unable to promote share mybooklive to music store. Invalid operation 'cannot authenticate share (followed by an IP address). Been at it for 4 hours now and giving up!!!
What on earth is going wrong?
No idea if it's a nas issue or an HDX issue ![]()
Are you trying to make the entire NAS promote to a share?
That may be the problem.
Try creating a network share on the NAS drive and then promoting this to the store.
It would probably work as you will create a "file" on the NAS which is music share ( rather than asking HDX to make the entire NAS a share).
Check the HDX instructions on creating a network share with the correct wording such as music)
Paul
Do you get an ip address that match your routers asignment. Often routers will assign ip addresses starting with 192.168.xxx.xxx. If you get other numbers in the 2 first groups, check if you use special dns services like open dns, or other such services.
This has created problems for both Naim and other upnp systems, even though Naim does not believe it.
Can you access the backup share from your computers on the network and if so with or without username and passwords?
Claus
It's been a while nice I looked at this, so may need checking, but I think you need to use dtc to set HDX backup and define where it backs up to, etc. it should then back upautomatically. I don't think it s designed to act a a back up by manually moving the files. I think that is a different process which is normally a function of "move music" which can be found on the HDX menus
Ray the backup utility wants to do its thing unattended -- every day it will see if you've added music and add the new stuff to the backup. If nothing new has been ripped that day, then there is nothing to back up. That's how to use the backup utility; let it do its thing on its own.
I hope that makes sense.
Ray,
Thats one of the reasons why i have moved all my music to the NAS drive, and do not have anything on the HDX (even though its the 1Tb version). I now have around 3700 albums on my system and it takes up 3 Tb of data on my 12Tb NAS drive.
I have had previous problems with multiple copies, and its anoying when searching through the music to play.
Hope all works out for you
Paul
Paul,
Nipped home an hour ago and everything has backed up. that took about 15hrs to move 500 cd's!
At least i can assume that it has been moved in HQ.
As I don't think I'll ever grow my collection to or above 1TB(about a third in use so far), i think I'll be fine now. It looks like(looking at dtc) NAS tried to perform scheduled backup at 4am but failed obviously because it was storing everything getting moved from HDX, then when everything finished it tried and was successful.
I think I'll rip something tonight and see if it's there in the morning.
Also, as my NAS has been set up(as confirmed on dtc) as a backup, I'm sure that I won't experience any duplicate copy issues etc.
Also, I think on your other thread, you didn't mention your 3TB storage, hence why like myself someone wondered why you wouldnt use HDX hard drive. makes sense now.
Thanks for the input.
Ray.
