n-stream and asset upnp
Posted by: balma01 on 03 November 2012
Using the naim uniti green display I can open my  'asset upnp' server and here I find  a menu called 'playlists' and  a section called 'new albums' where I see  my albums sorted by 'added date', the last album i've added is shown first and so on.
Using n-stream, in the 'new album' section I find my albums sorted by alphabetical order and not by added date. Why ?
Posted on: 04 November 2012 by DaveBk
It works ok with me - if I navigate as follows on nStream:
Asset -> Playlists -> [New Albums]
I get a list of my latest albums with the newest at the top.
Which version of Asset are you using?
Posted on: 04 November 2012 by balma01
asset 4 and the latest n-stream
Posted on: 05 November 2012 by balma01
Another very strange think is that when I'm in the 'new album' (and as said I see all the albums sorted in alphabetical order) and I press the 'search' field, it appears the 'new album' list sorted by added date as I need. Please help me to solve this annoying issue.
Posted on: 07 November 2012 by balma01
Discovered that turning on the n-stream parameter UPNP COMPATIBILITY MODE I'm able to see the 'new album' playlist.
DaveBk how is  your UPNP COMPATIBILITY MODE parameter ?
Please, can you check if turning it off you can always see the 'new album' playlist ?
Posted on: 07 November 2012 by DaveBk
Hi, I've tried with and without uPnP compatibility mode and get the same results - sorted in date added order as expected. There is a A-Z sort checkbox on the Asset advanced settings dialog box under the browse tree - what is yours set to for playlists?
Personally I find the help info on Asset rather poor as it does not really explain what the settings really change. It took me a while to find the pre-programmed playlists like New Albums, and I still don't really understand how to customise the behaviour.
Also, it would be helpful if Naim could explain exactly what uPnP compatibility mode does - it certainly caches locally and re-sorts, but what else?
Posted on: 08 November 2012 by balma01
Hi,
thanks DaveBk for your help. Unfortunately the  A-Z sort checkbox for playlists is not checked, so this is not  the problem. I will use the n-stram with upnp compatibility for now.
I can say you that if you write to the asset forum, Mr Spoon will always help with an answer. Anyway I use asset since 4 years and I'm able to customize it, if you nedd help just ask.
Thakns again and best regards
Posted on: 11 November 2012 by Dustysox
this is a good point that balma01 has raised, one that I have mentioned else where and could not get to the bottom of.
If anyone knows the solution please advise and put me out of my missery!
Posted on: 11 November 2012 by balma01
I'm not alone.
Dustysox, did you ask to the official naim support?
