USB Memorystick where??
Posted by: Allram61 on 15 November 2012
Hi
I have ND5-XS and a UnitServe both conectded with cable via the same router.
Some times i use a USB memorystick and have till today used the input on the front of
ND5. Is there anything (theoretically) that would suggest if its better to put it in another way, for instance.... "yes its better to put in the......... because...."
Thanks for input sugg.
//magnus
Posted on: 15 November 2012 by Guido Fawkes
Originally Posted by Allram61:
Hi
//magnus
On the Naim DAC I prefer the rear port, if there is one on the ND5 then worth a go ... otherwise what you are doing makes perfect sense ... loading the music directly in to where your ND5 can render it and your ND5's DAC can generate the analogue music ... sounds really sensible to me.
Posted on: 15 November 2012 by Simon-in-Suffolk
Agree with Guy, the rear port does sound better than the front on the NDAC if using a USB memory stick.
Simon
