app 3.2
Posted by: Leo on 21 November 2012
3.2 for iphone app does not recognize ND5XS, while the iPad 2 is, does anyone know something about it ... thanks Leo
Posted on: 21 November 2012 by Bart
Leo I am sure that it's a problem that your iPhone does not "see" the ND5XS.  When you go into the "Setup" menu, does nothing show up under "Select Device" at all??  If not, I'd start rebooting things -- start with the ND5XS, which will force it to get back on your network.  Then, reboot the iPhone and if that fails then uninstall and reinstall the nStream app.
Good luck -- should work!
Posted on: 21 November 2012 by garyi
Try closing the app the on the ipad.
Posted on: 06 December 2012 by Leo
Originally Posted by Bart:
Followed your advice and perfect everything works ... Thanks a lot
