question for dsbridge users
Posted by: divuk83 on 22 November 2012
I can't seem to get dsbridge to work anymore, or rather I can't be my Uniti to play the stream it creates! I can play it off my mac or my laptop (through the web browser) however when I save the ip of the stream to my naim presets it won't play. I can see I have the ip right as it tries to connect then fails.
ds bridge config file
[SPOTIFY.EXE]
MP3BitRate=320
HTTPPort=8124
TitlePrefix="Spotify - "
CoverArt=1
CoverArtX=0
CoverArtY=-275
CoverArtWidth=234
CoverArtHeight=234
MuteWhenStreaming=1
ClickOnConnect=0
ClickX=86
ClickY=-20
[ITUNES.EXE]
MP3BitRate=320
HTTPPort=8124
InitializeNetworking=1
MuteWhenStreaming=1
If anyone else has any suggetions or can confirm dsbridge still works with spotify (as there have a been a number of updates to it since I last used it) I would be grateful.
Dave
Posted on: 23 November 2012 by divuk83
I'm guessing no one uses DSbridge? Are there are newer alternatives to stream spotify from my w7 laptop to my uniti?
Dave
Posted on: 17 February 2013 by ianruneckles
I'm was using DS Bridge but since I updated my Uniti to 3.17 I'm also not able to stream from my XP netbook. So if there are any alternatives, or workrounds then I'd like to know! Also if it's possible from a  Mac? Maybe Naim are working on an easier way to stream from Spotify...
Thanks, Ian
