UQ as a source
Posted by: Robbert on 23 November 2012
Is it possible to use the UQ as a source? I would like to use it on my Pass Labs Pre amplifier.
I have to use the pre out.( i guess )
And it is possible to use the n-Stream app on the UQ when it is a source, and using the volume control?
See it like a DAC with volume controle.
Posted on: 23 November 2012 by Edouard
Hi Robert,
The Qute is a pretty capable source, I recently connected it to my 552/300 (pre/amp) and it works beautifully!
- You just have to connect the pre out of the Qute to one of the input of your amplification.
- You can also use the digital out of the Qute if you have a DAC. In this case, it's the Dac which will be connected to one of the input of your amplification.
I'm pretty sure you can use the n-Stream app.
Edouard
Posted on: 23 November 2012 by Robbert
I do not have a separate DAC. It must be the DAC from the UQ.
As i use the volume control, the sound will go threw the pre-amp section. And that's where it will go down. I understand when i use the digital out section.
Maybe i'm gone try it for a while
