I'm having a problem with n-stream. It keeps reloading so I get multiple copies of each album in my albums folder. Each album has loaded about 50 times and it's still going! Each artist only loads once. Any suggestions as to what might be causing this?
My music is stored on a Vortexbox Appliance, I'm running n-stream on an iPad and linked to a Uniti 2.
Posted on: 24 November 2012 by Iver van de Zand
not a clue; you could delete the nStream cash and see what happens. If it still proceeds, I'd delete the app from the iPad and re-install. If than, the problem still occurs, you might want to have a look at the "things" feeding nStream: ie. Vortex.
Posted on: 24 November 2012 by Simon-in-Suffolk
Kitty, this sounds related to your upnp server. assuming this config has worked before, I would reset your Vortexbox or temprarily try a different upnp server and let us know where you stand after that.
Simon
