My n-stream experience
Posted by: SamSam on 30 November 2012
I have a uniti on the latest firmware and the latest n-stream version used via my iPhone 3gs. Want here to share some of my experience with the set
- with the upnp compatibilty mode on, I have much less connection disruption  with the media server (asset upnp)
- with the upnp compatibility mode off, n-stream does not recognise the dash caracter '-' when browsing via the folders option in the media server. All caraters after the dash are completely ignored.
Did you experience similar issues
Have fun and thanks in advance for your feed-backs
Sam
Posted on: 30 November 2012 by Adam Meredith
https://forums.naimaudio.com/di...ent/3819189072977000 is where you will both do the most good (bug report) and obtain the best advice.
