New Superuniti!
Posted by: Roman Kozyrev on 21 December 2012
Congratulations Roman - the SU is a wonderful piece of kit - I used to have a top end olive separates system and I wouldn't go back!
As naimUnT says it's all in the box, even including a wifi aerial. If you have a home network then you should be able to just connect up the SU (preferably by ethernet cable) and it will sort itself out apart from you entering your network password. In the box is only a quick start guide that will get you going. It is worthwhile downloading the full manual from the Naim web site as that will enable you to use the full capabilities including such handy features as input trim.
Of course your dealer should install it for you and ensure it is working in your home but if your experience is anything like mine they won't bother - even though their profit margin is such that they should and some excellent dealers who post on here do. It can't hurt to ask them and maybe shame them into doing it (assuming they are competent with streaming products which is far from a given).
Good luck and have fun playing and listening!
Pev
OK - I guess even Naim dealer markups are not enough to cover a home install in your case ![]()
Good luck again - I'm sure all will be well and be assured that the SU has enough grunt to drive most speakers.
PUT an inline isolating transformer ,replacing earth on secondary .
Roman
I have heard Liutos recently with the SU, they sounded great!
Bobby
Don't forget to give it a few days to settle down, Roman, before becoming totally euphoric.
hi roman,
congrats on the new SU, i have one for 3 months now. Had the naim nait 5i and the cd5i before which was nice with Totem Hawk speakers. Excellent sound quality.
But then... i connected the SU. could not believe that my Totem Hawks were the same speakers as i had before. Everything was upgraded a 1000 times.
So be sure to check out those totem winds. they must be even better than my hawks! real nice!
enjoy!
Finally, I had returned Opera with some regrets... It doest look nice in my room and room acoustic was not right for them as well.. Room is to small for big speakers... Said goodbye to SF Cremona M, Opera Quita.... said hello to Totem Forest, then goodbye for them.... settled with Totem Hawks... great small floorsatnders, fits physically and acoustically into my room and my music taste! Works great with SU!
