can anyone explain...
Posted by: intothevoid on 27 December 2012
I was thinking about internet radio streams and how they are always quoted in kbps, whereas cd and hi-res is always referred to by bit depth and sample rate.
A cd is as 16/44.1 which should equate to 705.6kbps but, according to HDTracks, a cd is 1411.2kbps so my calculation is out by a factor of two.
The same holds true for a hi-res 24/192 recording which should be 4608kbps but HDTracks says it's 9216kbps. Same x2 discrepancy.
What am I missing?
On a related note, given that internet radio is generally transmitted using MP3 (lossy), a 'high quality' 320kpbs feed is barely a quarter of a cd's throughput, and a lowly 96kbps feed is a mere 1/15th!
Am I correct in my assertion, or should I go back to reading Janet and John?
Steve
Posted on: 27 December 2012 by spartacus
multiply it by 2 for stereo. Bit rate = (sampling rate) × (bit depth) × (number of channels)
Posted on: 27 December 2012 by intothevoid
bugger
Thanks for the heads-up.
Posted on: 27 December 2012 by winkyincanada
Plus a few bps for "admin"?
Posted on: 28 December 2012 by Simon-in-Suffolk
Winky, no the data rate quoted is just the media/codec data rate and does not include any header, encapsulation data or admin. So the actual data rate is therefore obviously higher than that shown.
Simon
