NDX won't play
Posted by: antz on 28 December 2012
Hi Guys
Seasons greetings.
My NDX is behaving strangely. I play a track via Unitiserve / UPNP and momentarily all appears well. The track shows up on the NDX display as if about to play, then the text 'Stopped - Press Play To Start' appears. I followed that request and the sequence just repeats. This also happened at first with my Macmini connected via UPNP / Playback. Rebooting everything worked initially - now the NDX appears completely stuck. It won't even work if you select a track on the NDX screen directly. Interestingly, the small box on the NDX display (right corner) that normally shows UPNP only shows a blank box - text is missing. Again, it appears stuck - initially making a connection, displaying the track etc and UPNP then 'Stopped-Press Play To Start ' appears. Help - Any ideas?
Thanks ,
Tony
Seasons greetings.
Thanks ,
Tony
