N-Stream Playlists Issue
Posted by: Mak on 30 December 2012
Hi,
it happened overnight that if i want to play one of my playlists created on n-stream, it tells me that the song is not available anymore or the server is offline. All songs in the playlist are marked with that red "X".
If i searching the songs from the playlist int the album view, i can all find and play them, so no issues here. Restarted my superuniti, uniti-serve, n-stream, n-serve but no improvement.
Anybody an idea how to get my playlists work again?
Posted on: 30 December 2012 by Harry
Try clearing the UPnP cache. And/or power everything including network components down and restart.
Posted on: 30 December 2012 by Simon-in-Suffolk
Hi Mark it sounds like your upnp has reindexed your media for some reason, or possibly the IP addressifo your upnp server has changed. I understand Naim are working to get  around the latter, but if the index is changed there is nothing Naim can do. Each item in your playlist is referenced by a unique reference that your upnp provides, and if it reindexes it could change these references. Best not to let your upnp server reminded if you use playlists on Nstream.
Simon
Posted on: 30 December 2012 by Mak
Harry, i cleared the upnp cache, also powered down everything.
simon, as i did ip adress reservation for every single device (mac adress), the changebin the ip is unlikely and i' ve checked that.....
could the problem with the re-indexation of the server also be an issue when unitiserve is the source? Thought this could be just the case when streaming off a nas?
So does it mean, i've to set up my playlists again?
Posted on: 31 December 2012 by Simon-in-Suffolk
If its not a case of your upnp server changing its address - then yes you do. It's a pain I know...  The indexing is to do with the upnp server and not the NAS (unless you have your upnp server actually on your NAS as well).
So you are using Unitiserver? Did you force it to re index? Perhaps one for Naim support when they return if it re indexed on its own.
Simon
