Ford Focus Conundrum
Posted by: Timbo on 02 January 2013
Just throwing this question out there to see if anyone can shed any light.
I have a Ford Focus 2002 Station Wagon and the two small lights that illuminate the registration plate keep failing, the fuse keeps blowing. I have tried a number of things:
Removed and cleaned light holders and replaced bulbs, replaced fuse. What seems to happen is the fuse will blow if the lights are turned on when the engine is running. However, if the engine is not running and the lights are turned on it is OK the bulbs will stay lit.
I thought the units might be shorting against the car body so took them out, still same problem. Tried using a couple of different bulb holders and bulbs from the supply in the tailgate and it still happens. Have checked the wiring loom especially the bit that runs from the car into the tailgate to make sure it doesn't pinch - seems OK.
It is only when the car is running and only these two lights, I wonder if there is something else causing this which is different or rather causes a new condition when the engine is running.
Would be grateful for any ideas from those out there.
Tim
Posted on: 02 January 2013 by Bill McLean
It would seem as though the alternator voltage control was giving too high a voltage to the battery. A decent auto electrician could measure this and advize.
Bill
Posted on: 03 January 2013 by Donuk
Timbo, have you tried sourcing your replacement bulbs from somewhere else - perhaps a poor batch.
Posted on: 03 January 2013 by Mike-B
If the fuse is blowing it means the fuse is overloaded
Wrong bulbs (maybe the blow process is causing a short circuit inside the bulb)
Wrong fuse (unless its a bad quality 1 or 2 amp - I doubt it)
I can't see why only these lights are blowing unless they are poor quality or below spec.  Other low power bulbs live in tail, front, & panel lights & no reason why these should not blow as well.
+1 for Bill - go get it checked out by an auto-electrician as it could be your alternator voltage regulator is too high & that needs a specialist. They will also be able to check all the other stuff & get it nailed.
NB:  Only go to a garage with a genuine auto-electrician or an auto-electrical specialist shop.
Posted on: 03 January 2013 by rich46
it is not the bulb, I guess the alternator stabization is at fault  s//  regulator     voltage not stable , increased volts causes more current, lamp blows
Posted on: 03 January 2013 by BigH47
Is there a flexi cable through the hatch/rear door that has worn insulation?
It would seem that if it's  limited to only a couple of bulbs over voltage might not be the answer unless these are very weak bulbs.
Good tip H,  only problem is if Timbo has written it correctly & I understand it right,  the bulbs blow as well as the fuse. If it is the tail gate hinge cable shorting, that doesn't account for the bulbs blowing.
Problem is the market has a load of low quality bulbs around that are not spec'd correctly for automotive 12v.  Although they say 12v on the box & bulb, they should be spec’d for around 14v for all car & truck 12v systems.  I advise with all bulbs is be sure you can see its from a well-known make.
Again I would repeat to go for an alternator check.  The US spec Focus alternator is 105 amps - a good size & able to poke out a lot of amps & volts if the regulator is going bad its well able to blow low spec bulbs.
Posted on: 03 January 2013 by Timbo
Thanks for your advice everyone. To clarify, the bulbs are OK, it is just the fuse blowing. If I put in a new fuse the bulbs come on for a few seconds and then the fuse blows. But only while the car is running, so the alternator is something I hadn't considered, the car is due for a routine service and I always take it to a Ford main dealer so I will get them to check it out.
Tim
Still doesn't make sense,  if it was the alternator other bulbs would burn out & it would not blow the tail light fuse.
Could be something like a cross connection in the tailgate hinge area across to the screen heater ????.
Go get it checked out by the garage.  And let us all know what it was for sure.
I was wondering that but I have managed to inspect the wiring loom in the tailgate and the first part of the car and all seems OK. But you are right a Ford Main Dealer should have all the right diagnostic equipment and hopefully should be able to identify the problem.
Tim
Tim
tail lamps are very low there resistance is so they are fragile
Yes the fuse is rated at 7.5
I will let you know the outcome.
Tim
Posted on: 03 January 2013 by Nat1974
Just a thought, but does the fuse feed anything else? Perfault the fault is elsewhere...
Posted on: 03 January 2013 by Cbr600
Good point, there has to be other items on the circuit. Ford would not provide a fused circuit just for rear number plate lights
Please excuse my spelling, replying on an iPhone is never a good idea with chubby fingers!
Had a look at this, it seems the licence plate lights are the only thing on that circuit, nothing else seems not to work.
On a separate note, have been listening to my unitiserve most of the day thru NDac, XPS2, 252, 300 and SL2's - fantastic!!!!
Tim
