Playlist for Unitilite with NAS
Posted by: BR on 03 January 2013
I have a new Unitilite and a Zyxel NAS325 attached. Works fine except the playlists. The Lite reads a list only if songs are in the same directory as the list. All other lists are found but are empty for the Lite.
Means I cannot make lists using songs of different albums. This makes playlists unusable.
Has anybody a solution to that?
Or does it means that all songs have to be in one directory?
What is the required syntax of Unitilite playlists?
Posted on: 03 January 2013 by Alamanka
Check this out:
"Can I create playlists for uniti?"
https://forums.naimaudio.com/di...94#11281028939743794
Posted on: 07 January 2013 by BR
Thanks for the link,  .... but the entries dont show the success really.
Your hint with the server name did not yet work with my Twonky NAS.
\\nas325\music\folder\title.flac   ... doesnt work
My Lite plays only one syntax:
title.flac
.. when the list is placed in the local directory. No directories are accepted.
Playlists in one album are not really helpful.
Is there a paper on how to deal from a Uniti with playlists and NAS?
Are there papers on playlists on UPNPs?
I added an ipad plus nstream app this weekend. works fine.
Here I can enter playlists, also new ones but they seem to be local on the ipad.
Where/how can I find these lists, send them to my pc and extend there?
BTW: Ho w can I delete these playlists on an ipad?
