Ipad posting.
Posted by: Dustysox on 07 January 2013
Hi all,
I am still without laptop. I miss being able to post album cover pics etc I've checked FaQs, and I'm not sure if it applys to ipad method. How does one post pics via ipad?
Any help...please?
I'm replying from an iPad, so we'll see if this works...
1. Copy the image to your iPad (hold finger on picture until Copy / Save option appears)
2. Now, back on the forum, in the Post Reply window, hold finger on window until the Paste option appears. Select Paste.
If this works, you should see a CD 555 below ( it shows on my iPad).
... And now it doesn't show. So much for that method.
OK, got it now :
1. Copy the image
2. Open a new tab in Safari
3. Paste the picture into the address space (this inserts image URL into address bar)
4. Select the full URL in the address bar
5. Back on the forum, paste that into the image URL space in the Post Reply window.
Do you see the CD555 below ?
Fantastic Jan-Erik!
Thank you so,much.
One other question, or is it me!! I seem to have to "hit" buttons/links on the Naim forum to open "stuff" several times. It does not happen on other sites just here. Is this correct?
i do not have the problem of hitting buttons multiple times on my ipad, must be a local issue.
Its great to see how to post pictures from the pad. never been able to do that before.
nice one
Hi,
Multiple "hits" might be misleading on my part. Certainly on a couple of "hits" might be nearer the mark. We have both ipad 1 & 3 with the same issue on my home network and other networks. Not convinced it's a local issue. I'm sure. i have read else where on this forum with others experiencing the same issue.
Thanks Jan-Erik. I tried to post via Imageshack but it won't let me copy the direct link. I'll try your method.
Steve
Great. It worked. Thanks.
Hi Steve, try again (the second method I describe) , the image is not showing on my iPad.
Jan
Hi,
I've noticed this too....sure it was after ios6 was installed...? G
Thanks for the heads up Graeme, I thought it was me.
Strange how it just happens on the Naim forum?
Another Hoopeless addition I think.
So much easier to post on the wam and pink fish which both are tapatalk compatible.
Test of iPad image. Copy
10-4 Good Buddy receiving you loud n clear!
Seems to work before I press Submit Reply.
Sent via Carrier pigeon
Can't you just put it in a jiffy bag?? ![]()
Good point. I just wonder how many people have this issue on ipad.
Maybe if Hoopla are listening.....cue the jokes!!
Same issue here in an iPad 3. For example, to reply with quote requires hitting the " icon twice. If only the rest of life's problems were this *important*...
