airpot express problem with new minipad,
Posted by: o.j. on 09 January 2013
Hy ,bought a 64 gb minipad and anairportexpress.the express is my new homenetwork router and works perfekt.
wanted to go digital optical fromairport express to my stereosystem (cambridge d/A converter,
and my problem is;wlan music that is in my minipad is often disturbed .srange tones or quiet for
moments.
My computer buddy plays the same music insame format wthout any problem fromhis airnotebook into my airportexpress and into my stereosystem.
He said:te problem could be:the lan output of my minitab is less than from hisairbook.
and he suggestes the following solutions:
to bring my airport express with longer cables a little bit higher in teh room for better radar wave tuniing.
do not know the correct vocabulary,sorry.
other solution ;to go for an airport extreme. i would prefer that as a solution.
S o what do you think ,will my problems be solved.
i mean ,if apple produces wlan ipods and minipads,it seems to mee a must that they work with airport
routers together. i live in an old building with only twelve flats,and my other old laptop
that has no w lan is connected by cable to the airportexpress.
any Ideas ,friends????
