An oddity I have found with Thumb Drives:
Posted by: Russ on 12 January 2013
OK, so I have found a way around it, and so am not posing any questions, but I thought I would throw it out there as interesting, though not very: I do not yet have a VTB Appliance hooked up--though that will come soon. So as a temporizing measure, I have been putting albums I really want to listen to onto various SanDisk Cruzer thumb drives of 16 gig capacity. Before using them, as they are, in FAT32 format, I delete all the various files provided on them, which I assume are for use as backup devices.
So, using an old laptop with Vista and a jury-rigged external CD drive because the one on the laptop has breathed its last, I rip CD s to FLAC format, level 5. I can then move them with no problems to other files set up for the purpose. Also, the first few files I move to any of the thumb drives go over there fine--albeit quite slowly. But I figure what the Hell, I move a lot slower myself, nowadays. But after that, when I try to move an album over, the movement gets hung up between tracks. (or when I try to move a large 192/24 download file, such as one movement from a Beethoven Piano Concerto--watch out--it gets hung up. But there is no rhyme or reason. After I delete the partial file from the thumb drive and try again, sometimes it works and sometimes it gets stuck--but in a different place every time. When this happens, my only remedy is to pull the thumb drive out without regard to the "Now it is safe to remove..." message. Then I plug it back in and I get a recommendation to run a diagnostic on the little drive. I do, and it is invariably OK. I then delete the partial file and try again.
Also, it ain't just one thumb drive--it is in fact every one I own.
But last night, I tried an experiment: I re-downloaded Beethoven's Fifth Piano Concerto at 192/24 onto the same partially full thumb drive that I failed with on my laptop--onto my wife's super duper pooper scooper Dell XPS with Windows Seven. Never a problem.
I think it is the Good Lord punishing me for a misspent life. I can only suppose that if I had lived an even more dissipated youth, He would have caused the process to fail on the desktop as well. ![]()
Best regards,
Russ
