R Com & NDS
Posted by: Doc on 20 January 2013
Does anyone know if the R Com will control the NDS
thanks
Rcom is the statement product.
It lives in its own world and it gives the deaf vistors an idea of why our audio systems may cost that much ![]()
I find NARCOM as extremely robust and ergonomic solution.
I still think that Apple remote is the best.
When I saw it operating the very expensive Vitus electronics I had to admit that both NARCOM and RCOM lack the same elegance.
I would also be very intrested to know the answer.
At least my NDX doesn't obey RCOM at all.
I'm sure Naim could add this as an option for all streamers, but even rec mute & balance adjustments seem to be beyond "System Automation" (and n-Stream)... What a shame.
There are some (undocumented) IR options in Advanced Setup, but I'm not sure if those could be "hacked" to support RCOM in any way.
Thanks for letting me know
It is a shame, as I tend to use the Remote a lot to alter volume and flip through tracks that I have chosen on the IPad
The R Com feels great in the hand and it would have been a nice to have had the option...
Indeed, a shame. I looked at mine, admired it's weightiness and quality of build, then when I found out it didn't actually do anything other than control the 552 packed it away again. Kind of a wasteful product in an ecological (?) world!
