Arcam airDAC to naimDAC for AirPlay capability instead of AirportExpress?
Posted by: Disposable hero on 23 January 2013
Could the new Arcam airDAC be a worthwhile replacement for an Airport Express in terms of raising sound quality, if then fed onto a naimDAC?
Looking at the Arcam blurb from the CES show blog (quote below) it features digital outputs, if intending to Airplay to some other DAC instead of DACing itself?
Could the airDAC bring any benefits to AirPlay streaming over a bog-standard Airport Express or other such device, or would it not make any difference?
If using the airDAC to do the DACing, my only reservation with the "Arcam sound" was that it was immensely boring, having once had an alpha 7 CD player long ago.
As you might expect the airDAC has RCA analogue audio outputs with sublime sound quality, using a high-end DAC chipset from Texas Instruments and properly regulated, ultra low noise power supplies. But the airDAC also has another trick up it's sleeve, digital outputs in both Coaxial and Toslink formats. These allow connection to ultra high-end DACs like the D33 and open up a whole new raft of system possibilities for mobile music devices.
