Problem updating to 3.17 SU
Posted by: Dwamish on 02 February 2013
When trying to update I get an error message saying  "failing to he discover the product on the network". However above it says product model and network address 192.168.1.4 and when I go into the SU setup the ip-address is the same 192.168.1.4? Still it ask me to retry... What should I do?
I am connected wired.
Anyone?
Posted on: 03 February 2013 by Pev
I had that but there is an option to type the ip address directly into the updating software after it failed to find my SU and that then worked for me. I also had to do it once later in the process when the actual download started. All works fine now.
Posted on: 03 February 2013 by Dwamish
Thanks!
Yes there is an option to type it manually. But it does not work it asks me again to retry every time so? Anyone?
Dwamish
