Unitilite and the itouch trap
Posted by: Matthew Townshend on 12 February 2013
Wonderful new unitilite but why only ipod etc 5th generation? I can use my 4th itouch as a remote control - fine, but can't connect via usb. Is this really the case?
Posted on: 12 February 2013 by Jan-Erik Nordoen
That's odd. According to the manual, the 4th gen iPod Touch is compatible :
http://www.naimaudio.com/sites..._english_issue1d.pdf
Posted on: 12 February 2013 by Matthew Townshend
Yes, thanks for this, you're quite right. However, I've just realised that they specify 8, 32 & 64Gb but not 16Gb. Could this be the problem and does anyone know why?
Posted on: 12 February 2013 by Guido Fawkes
Drop Naim a direct e-mail, they'll soon confirm whether it should work.
Technically, i don't understand why it wouldn't.
